Hi, Very annoying issue.
The floorplans on our sheets have tags. Those tags are all horizontal.
Now someone has placed all the Ceiling plans on sheets and some have been rotated (i believe they've rotated the whole ceiling plan instead of just the crop view). Now all tags are vertical and refuse to rotate horizontally, no matter what i do.
I've tried reapplying the floorplan to a sheet and only rotate it's crop view, this does not work. Revit simply throws the floorplan offscreen and does not rotate anything at all.
i've tried opening the tag family and rotating it in the family, also revit refuses to apply the rotated tag properly when loaded into the project, they just remain vertical. Yes 'keep readable' is turned off. Hell i even loaded the tag itself in upside down, revit still just puts it vertically or upside down... WHY. Tags are supposed to be readable, who thought it would be a good idea to have them flipped on a sheet............
in the tag family uncheck "Rotate with component" :
for more explain:
@m-de-lange wrote:Now someone has placed all the Ceiling plans on sheets and some have been rotated (i believe they've rotated the whole ceiling plan instead of just the crop view).
Why don't you ask how they rotated the view? That should allow you to orient the view correctly and you tag should be correct.
Hi @m-de-lange
Thanks a lot for posting your question to the forums! Has the solutions suggested by @azad.Nanva & @RSomppi helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
