I really dislike that tag options have been removed from the options bar in the latest revision of the user interface. Now, before placing it I have no choice about how I want a tag to appear. I have to place the tag first and only then can I remove the leader, set it to be "free", or change the tag orientation. What gives, Autodesk?
Unfortunately, the properties pallet often doesn't become active until after tagging the object.
It's active immediately upon initiating a command - just like the Options Bar. That's how Revit works. If it isn't working that way on your end, then that's the real issue here. Maybe you should open a support ticket on this through your auotodesk.manage.com portal.
Maybe so. BTW, I'm using Revit 2025.2 (20240715_1515(x64)), which I believe is the latest update. And we have 2 workstations exhibiting the same behavior.
