Tags: Leader
6 ANTWORTEN 6
Nachricht 1 von 7
XXalessio.amodioXX
426 Aufrufe, 6 Antworten
Tags: Leader
Hi all,
I want to create a 2 color tag. (Red and Black, Buble + leader)
If i assign a subcategory to a tag I can change color.
Issue comes from the leader (Color leader reflect Category Tag color).
Any idea?
6 ANTWORTEN 6
Nachricht 2 von 7
kadmonkee
als Antwort auf: XXalessio.amodioXX
create 2 separate families each able to change color and nest one into the other with parameters to control color by different subcategories
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 7
XXalessio.amodioXX
als Antwort auf: kadmonkee
Hi.
I think is not possible to nest Tag families. If so cna you show me how?
Nachricht 4 von 7
kadmonkee
you can actually nest annotative generic tags but the leader color will not adjust to color
start with a generic annotative family create the first family as the host, save that one  then save as to create the second family rename it and change the parameters you need. save that then load it into the host family follow how the symbol parameter in the host is assigned to the nested family
2 families attached in Revit 2019
the host family = RED the nested family is BLUE open them both see how they are created , category  sub category assignments etc.
parameters for visibility as TYPES
depending on what you are tagging only place the tag label in the host family and manage the geometry as a type (RED or BLUE)
thank you
Nachricht 5 von 7
XXalessio.amodioXX
Thanks for you reply but "you can actually nest annotative generic tags but the leader color will not adjust to color".
That is actually the title of the tread.
Nachricht 6 von 7
kadmonkee
the thread title is TAGS: LEADER
regardless of the title if its a category that drives the color of the leader then assign a category that you can change the color of.
otherwise a workaround is to not focus on a color of a leader but what the leader is pointing to and the information it provides from the tag of any color then create a legend that explains what each color means
thank you
Nachricht 7 von 7
XXalessio.amodioXX
Many thanks for your effort I appreciate it.
I think that a good solution could be as you said.I will use same color for all the tags leader and prepare a legend for the bubble color meaning.
