Please advise with Revit 2023
When I create a new family then add Item Number in parameters ( make it shared parameter) , then upload item in to the project - why schedule doesn't pick this new item? so as tag wouldn't show its Item Number when in place.
(I do change Item in to Specialty Equipment and Upload tags for Specialty Equipment)
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
There could be any number of reasons its not working. Its hard to say what it is from your description. Are you sure you made it a shared parameter? Is it the same shared parameter in the tags? Are you sure the shared parameter is the one you scheduled? Did you make the family the right category?
its definitely a shared parameter
Item is under specialty equipment
In tags parameters, under specialty equipment I have uploaded Specialty Equipment Tag (from folders - Annotate - Architecture - Specialty Equipment Tag
Are you sure the shared parameter is the one you scheduled? - not sure about that, could you please expand your question
thank you,
A
Post your file here to avoid the guessing game. We can then tell you exactly what's going on and how to correct it.
Item number - 1.05
tag wouldn't show Item number
this is how I uploaded Tag
tag has been assigned to specialty equipment as well,
I cant figure out what else I need to do that Tag would show an Item number
could it be that I haven't downloaded full version?
What is the tag reading? Did you open the Tag and look? Maybe it isn't reading what you want. If you want it to read a shared parameter, then you need to use the shared parameter in the tag as well.
