Tagging wall dimensions and automatic description
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Marie.j03
461 Aufrufe, 3 Antworten
Hi all. I have two questions regardings walls
1. I am trying to tag the dimensions of the wall so I edit the tag family in the project but in the list I do not have any dimesnions parameters
2. My second question is about the wall description. Is there a way to have an automatic description of the wall or I have to type it in always?
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Marie.j03
@Marie.j03
What tag are you using :denkendes_Gesicht:... make sure it is a Wall Tag
For the description...you can try out Keynotes. It is simple and easy and you can create a custome database for all elements not just wall. Yeah you need to set it up first then it becomes automatic
Nachricht 3 von 4
Marie.j03
als Antwort auf: RDAOU
thanks you are right it was a multi tag category
I know keynote. I thought there was a description parameter which can detect info from the the wall
Nachricht 4 von 4
RDAOU
@Marie.j03
No there isn't... but you can do that either by using dynamo or a plug-in. There are several which add this feature
https://apps.autodesk.com/RVT/en/Detail/Index?id=7780462665166729539&appLang=en&os=Win64&_ga=2.15010...
