Tagging linked windows
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
chrisUPB84
606 Aufrufe, 10 Antworten
I am linking multiple units to another project, I am wondering how to give each window a separate mark so I can tag and schedule them correctly in the main project. At the moment, the windows are retaining the mark from the linked project, and I can not change this in the properties box.
Thanks, Chris
10 ANTWORTEN 10
Nachricht 2 von 11
BIM-CONG
als Antwort auf: chrisUPB84
I haven't catch your problem clearly, did you link other models by linked view, in which you can see the tags but not able to change? Actually you can tag the windows which in the linked model, by selecting "Include elements from linked files", see below
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
Nachricht 3 von 11
ennujozlagam
https://knowledge.autodesk.com/support/revit/learn-explore/caas/video/youtube/lesson/143614-courseId...
Nachricht 4 von 11
chrisUPB84
als Antwort auf: BIM-CONG
Hi BIM-CONG, thanks for the reply. I can tag windows OK, it is the mark I want to change to the windows.  Because I am using the same house many times, I have linked 1 project into the main project multiple times.
What this means is that the mark remains the same in the properties. I am wondering if there is a way to make this unique in the main project?
Nachricht 5 von 11
chrisUPB84
als Antwort auf: ennujozlagam
Hi
Thanks for the reply,
I Can tag windows. The problem is if I number the windows in the linked project 1-10.  I will have 8 windows 1, 8 windows 2, 8 windows 3 and so on.
I am wondering if there is a way to have it so I can have a unique window number for each window.
Chris
Nachricht 6 von 11
BIM-CONG
Oh, I got it. Since the "Mart" parameter is belong to the window of the linked file, you can't change it in the main model, and tag is used to "draw" the information from the parameter, kinda "read-only".
In this issue, I think it's not easy for you to tag different "Mark" of same windows. I have an alternative suggestion which may help.
1. Add some shared parameters to the windows for each unit you would linked in, and add project parameters with them as Instance. For example, you could give the window some parameter as "Unit 1 Mark", "Unit 2 Mark"...and so on.
2. After that input the Mark you wish for each window and for each unit.
3. In the main model, you can use different type of tag to get different "Unitx Mark".
4. You can also use schedule to get the unique mark information in this way.
I know it's a little complicated to do it in this way, but I haven't get a better method yet. Hope it helps.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
- BIM THE FUTURE -
Nachricht 7 von 11
ennujozlagam
click the window then you can go to properties and change the MARK annotations type? thanks
Nachricht 8 von 11
ennujozlagam
Is this what you meant? Thanks
Nachricht 9 von 11
chrisUPB84
Hi again and thanks for responding again.
It is an interesting idea, and once set up I think it will work, Thanks.
Chris
Nachricht 10 von 11
chrisUPB84
Hi again, and thanks for the response and the video.
I think what you are suggesting is having a unit design within the host file, and linking another unit in to it. Unfortunately this still wont work as I have 53 units with only 2 types so I have each of the linked files imported 26 & 27 times, this will still repeat the window numbers.
Thanks, Chris
Nachricht 11 von 11
- name each Link instance with a unique ID
- add a Combine Parameter consists of RVT Link: Name and Window's Mark
