I know this have been repeated and repeated.
But can someone explain the logic?
Why cant we add a generic tag to a legend component type, when I can add a material tag to a single part of that same legend component?
It doesn't seem logical that I can tag the timber frame of a window but can't tag the entirety of the same window as W-101.
This is doubly strange considering that each window type has its corresponding legend component.
I understand why tagging instance parameters in legends will not work, but surely type parameters must be possible.
Normally this whole thing doesn't bother me, as we use the legend phasing work around. But when it comes time to train a new user, its so counter intuitive to explain that they cant use the built in legend views, which seems like the logical choice, because the information cant be coordinated. Instead they have to create some "invisible" walls and windows that may or may not exist in time depending on a little drop down box in the view settings, it's all just...... pathetic, really.
In a software that is supposed to be about coordinating data across all aspects of construction documentation to avoid mistakes, not being able to extract that data from a 2D representation of a 3D object is a bit silly.
Imagine the documentation possibilities that something so simple as tagging legend components will open up?
Tired of work arounds rant over.
Gelöst! Gehe zur Lösung
Gelöst von Karambaki. Gehe zur Lösung
I've recorded your input,
Will contact the Revit development team then, and ask for the feature to be fixed
if you please provide the details with some screeshots if possible to :
karam.baki@gmail.com
This has bugged me for years.
It's so frustrating and such a limitation on the program, and I guess so easy for Autodesk to fix.
There is another thread on the subject here.
http://forums.autodesk.com/t5/revit-architecture/tags-for-legend-components/m-p/5841391
I have been following this discussion in many different threads for years. We are really looking forward to being able to tag legend components intelligently with the Type Mark parameter.
All I want for Christmas is to not have to use Dummy tags to do this anymore.
Happy Holidays All!
They're working on it... for more than 4 years? Why this isn't even on Revit since the beginning? It's basic BIM for documentation purposes at least... texts to show parameters shouldn't even be allowed!
Please hurry with this solution!
