Tagging Beam Systems
I am having trouble getting Beam System Tags to appear in the floor plan I need them in.
Revit's default appears to be to place the span tag in the floor plan above the beam system. I however, need the span tag to appear in the Floor Plan below the beam system.
Is this at all possible?
constantin.stroescu
Select the Tag > Mode > Edit Family > View > Visibility Graphics > Annotation Categories - check Reference Planes -
Group the Label and the Rectangle Border. Create an offset parameter from the Reference Plane for the Group - Load the Family into the Project.
Use the parameter to control the Tag position from the center of beams...
Constantin Stroescu
constantin.stroescu
I've attached the Tag family....a little more flexible that the family from the screencast.....
Constantin Stroescu
Thanks for your response. This is a useful tip. I am actually looking for a way to use the Span Tag on beam systems that are in the ceiling of a floor plan. For example, the beams are located in the second floor floor plate, but I want to tag their span in the First Floor Plan.
Is this possible?
constantin.stroescu
Yes, it is.....
  1. Using View Range in the bottom Level ( increasing the Cut Plane Level) make visible the Beam System from the Upper Level.
  2. select the beam system > View >LineWork ( LW ) >Line Style - Overhead - click each beam of the system - the line will became dashed
  3. decrease back the value of the Cut level from step 1 to average 1,20 ( or your usual cut plane position)
  4. Tag the beam system in bottom Level
Constantin Stroescu
