TAG wall sweeps
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
9434 Aufrufe, 11 Antworten
TAG wall sweeps
How do I TAG a wall sweep in Section?
I know I need to use the TAG material... but is not working in section.
Any thoughts?
Tags (2)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
Create Parts and tag it, maybe?
Nachricht 3 von 12
I can tag a sweep with a Material Tag in section view. What's happening when you try?
Nachricht 4 von 12
als Antwort auf: barthbradley
Nothing... I cant select the sweep...
It is note getting the blue line....
Nachricht 5 von 12
Nachricht 6 von 12
@Anonymous: ...or, it's pinned and you have restricted selecting pinned objects (bottom-right).
Nachricht 7 von 12
No problems here either, both in-wall and in-place sweeps.
Nachricht 8 von 12
als Antwort auf: ToanDN
I am wondering if it is because I am tagging a linked model...
Could this be the problem?
Nachricht 9 von 12
Nachricht 10 von 12
No problem tagging wall sweeps in a link either, and I even set links to not selectable.  Can you use the material tag on anything else in the section?
Nachricht 11 von 12
It is working now. The wall sweep is a very thin profile and I need to click on a very specific point to get the Tag.
Tks everyone for the help
Nachricht 12 von 12
A.elshafey
 I believe that wall sweep tag feature is available on Revit 2023
