Tag types do not save/override when uploaded to project
2 ANTWORTEN 2
Nachricht 1 von 3
adamskaEXHPY
237 Aufrufe, 2 Antworten
Hi :leicht_lächelndes_Gesicht:
I am editing some tag Families and struggling with the fact that the changes do not save when the tag is reuploaded and overridden.
There is no problem when I delete the Family in the project and just upload it as new - all created or edited types work as intended.
However, some tags are already used in views and I can't delete them - so I need to figure out that the hell is wrong.
Any idea?
Thank you :leicht_lächelndes_Gesicht:
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: adamskaEXHPY
@adamskaEXHPY
What did you edit in the Tag? the type names? Renaming a type in the family will not rename the same in the project. It will simply create a new type.
After you upload the tag...select all the old tags in project and from the type drop down menu pick the new type which you have loaded into the project
Nachricht 3 von 3
RSomppi
Rename the old one.
Load new one.
Select all instances of the old one in your preferred way and replace with new.
Delete the old one.
