I have some skylights in a project that need to be tagged for the fenestration schedule. There will not be a reflected ceiling plan, so I need to tag them in the floor plan. Is there anyway to do that since the skylight is above the cut plane? I can an underlay and add annotation lines easily enough to locate the skylights in plan, but Revit doesn't want to tag them if they are not in the view.
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
You could make the skylight show up in the floor plan by using a plan region with a different view range. But that might look a little confusing in your floor plan. However, on a second thought, after using the plan region you could override the visibility of the skylight to be dashed lines.
Another alternative si tag the skylight in another view, an elevation view or a roof plan.
