TAG ROOM problem
6 ANTWORTEN 6
Nachricht 1 von 7
419 Aufrufe, 6 Antworten
TAG ROOM problem
hi ,
why i can't see scheme paint little part , and i can't room tag  ( room 28 )  ...only accepted on the scheme
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Hard to tell from just this picture.  Post the file.
Nachricht 3 von 7
als Antwort auf: barthbradley
Thank you ,  and there is one problem more,   when i export with all combinations for autocad  ... there arent  frame and project cover .. also  the whole project is scattered  . Project attached
Nachricht 4 von 7
bin
It's the roof...
Nachricht 5 von 7
als Antwort auf: bin
it's attic , room 28
Nachricht 6 von 7
bin
Create a section in your floor plan, then turn on the room fill in VG, you can tell that something is there.
It's the roof that makes the roof too low to cut in the floor plan.
You can either untick the Room Bounding of the roof (may affect the height of some other rooms), or just edit your roof to something like this.06082019.PNG
Nachricht 7 von 7
ok , you are right ..problem is roof, i did it ..thank you so much vg
