Hi, how to show all layers of subrgare in RVT24? When trying add tag it show family
Your question is not clear. I suggest to write your question in your own language, then use Google Translate to get an English text. Then edit your post to include that text.
The subgrade contains of 3 layers: concrete 100 mm, gravel 300mm and sand 300 mm in total 700 mm.
I want to add legend with all these 3 layers with tichkness.
Using "tag" it show just name of pamaly exp. "subgrade".
I understand that you want a tag to show 3 materials of a subgrade (maybe a toposolid?) that has three materials, concrete, gravel, and sand. But what "tag" are you referring to? I don't see a tag in your illustration, only callouts.
If that is a toposolid, you can use a Material Tag, but one tag for each material. The material tag is not going to show all three materials at once.
BTW, @ziogas_giedrius : That was a hail mary pass. I don't fully understand the question either.
