Tag for the room materials
3 ANTWORTEN 3
Nachricht 1 von 4
mairh_tsek
1662 Aufrufe, 3 Antworten
Hello all,
Is there any way to create a Tag that will indicate/recognize the materials that are assigned in a Room for the walls, floors, ceilings etc?
I know that I can use the Room parameters 'Wall Finish' , 'Floor Finish' etc. but I need to complete them manually.
I am wondering if it can be automatic.
Thank you in advance!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: mairh_tsek
Create a schedule and do it there.  You can even create a key schedule to further automate.
https://www.youtube.com/watch?v=wXfe22WwLZY
Nachricht 3 von 4
Corsten.Au
What you are asking is simple....but your assumption is Room might have only one type of wall, with one type of material finish..
Consider this..
one room, with 10 different walls, with 10 or more different finishes...
Multiple ceiling type varying heights and finish..
then whatever smart tag you use is not going to extract information from all those walls finishes..
Your option is to fill Room with Finish Tag manually..
or Create a Custom tag, but theres no automatic filling of information that easily..
Corsten
Building Designer
Nachricht 4 von 4
als Antwort auf: Corsten.Au
Actually, if @mairh_tsek wants to do that; ROOMBOOK is fantastic.
