Is it possible to create a tag for both windows and doors header. I only need the tag to report the opening width.
Yes but you need some work because a Muti-category tag does not report inbuilt dimension parameters across different categories. Follow the steps:
- add a dimension shared parameter to both door and window families
- add Width to the formula box of the shared parameter in both families
- create a label in a Multi-category tag and add the shared parameter to the label
I would just create a door tag, that reports the default "width" parameter. Save, then copy that tag family and change the "Family Category and Parameter" from door tag to window tag. Save, and use.
