Tag floor structures & thicknesses
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
Adrian.Fern7TWHK
710 Aufrufe, 1 Antwort
Currently when detailing section views of floors/slabs we manually label each layer of a floors structure with the material and associated thickness (see attached example).
Can anyone tell me if it is possible to do this as a single tag that would give each layer's material & thickness running top to bottom in the order that is in the slab properties?
Any assistance would be greatly appreciated.
1 ANTWORT 1
Nachricht 2 von 2
rxi.gg
als Antwort auf: Adrian.Fern7TWHK
Have a look if this thread can help you
https://forums.autodesk.com/t5/revit-architecture-forum/legends-for-standard-construction-from-struc...
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
