Tag Family Instances
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
wlawsonXCGKS
241 Aufrufe, 2 Antworten
How can you add individual asset tags to instances of the same family loaded into the same project file?
For example an Asset/project file contains 68 of the same chair (all shown using the same Revit family) each individual chair shown needs to have its own Asset Tag, how can you add this Asset Tag to each individual instance of the family, but still using the one same chair family?
2 ANTWORTEN 2
Nachricht 2 von 3
alan.johnson7YLND
als Antwort auf: wlawsonXCGKS
Create a Shared Parameter for the Asset info and then add it to the Chair family as an Instance Parameter
Then create the tag using the same Asset Shared Parameter
Nachricht 3 von 3
Use Mark or Comments parameter to enter instance Asset value.
