Tag elements
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
482 Aufrufe, 7 Antworten
Tag elements
if want to create a family in revit this is a resunt.
My box is empy.
What can I do please?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
...so add your own shared parameters. Easy-breezy. But the element you're tagging will also need to include that same shared parameter. The value given to the element's shared parameter will be "read" by the tag on placement.
Nachricht 3 von 8
als Antwort auf: barthbradley
@barthbradley what can i do?
descrive please procedure of what can i do. not generical consideration please, don't undrestand.
Nachricht 4 von 8
See that little icon in the lower left corner? That allows you to create a new parameter.
Nachricht 5 von 8
Now go. Don't know. thank's aniway :zwinkerndes_Gesicht: :leicht_lächelndes_Gesicht:
Nachricht 6 von 8
First of all - THAT'S NOT A SOLUTION, so don't give yourself credit where no credit is deserved.
Second, if you want help from us on this forum, it's a two-way street. You need to provide intelligent questions and feedback to those who you are seeking help from. Otherwise, you're going to a lone wolf out there that nobody wants to bother with.  Get it?
Nachricht 7 von 8
If now have this screen like in the attached  doing nothing and the problem is solved itself what can I do? Say that have the problem yet?!
Don't know the reason but now is so. I can't use revit very much. If the problem solved itself think only is a blessing beacause is not a very simple program.
I don't give credit to me but to you.
Have a good evening.
Nachricht 8 von 8
I don't give credit to me but to you for try to help me.
Anyway the "little icon in the lower left corner? That allows you to create a new parameter." After I click and have to search on the browser?
