Tag all not tagged not working on horizontal structural columns but works on vertical
8 ANTWORTEN 8
Nachricht 1 von 9
stereomp34
455 Aufrufe, 8 Antworten
 When using tag all not tagged I get this:
all vertical structural columns are getting tagged but all horizontal ones aren't. Any idea how to fix that?
8 ANTWORTEN 8
Nachricht 2 von 9
ralphdenhaan
als Antwort auf: stereomp34
I think your horizontal model elements are Structural Framing category? You need to load in a Structural Framing Tag in order to see them in the Tag All function.
I attached the default tag family for you.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 9
"Horizontal structural column"?  You mean the column’s base and top are at the same height?  That's not possible. Can you share the file.
Nachricht 4 von 9
stereomp34
als Antwort auf: barthbradley
Unfortunately I am not permitted to share files but here are 2 screenshots showing that both elements are indeed structural columns. I am not sure how they achieved it but they both respond to call for categories > structural columns > all elements of category in dynamo meaning they are indeed structural columns.
Nachricht 5 von 9
jvpantin2
There's something strange, because they're really VERTICAL columns (as shown in properties palette). Fake "horizontal" columns can be done with slanted option, and can be tagged also. Seems more like a family modelling/parameter issue...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 6 von 9
kostask_oionei
I notice that both Column Style is vertical.
Check your tag family, maybe you use a parameter that there isn't in both column types .
By the way i think is better to use beams (structural framing) as horizontal members.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 7 von 9
stereomp34
als Antwort auf: kostask_oionei
Yup.
The horizontal columns use parameter "L" and doesn't use "Length"
The vertical columns use parameter "Length" and doesn't use "L"
Do I need all parameters to match to use the tags properly?
Nachricht 8 von 9
jvpantin2
Obviously. First of all check the parameters in tag, label parameter must be the same as in family. But, as said by you, seems that "L" family parameter is custom-created (not the default "lenght" family or category parameter), so it needs to be a shared parameter in order to work. In that case, you have to load the parameter in tag family and use it in the label.
Nachricht 9 von 9
kostask_oionei
1. Create shared parameters: https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-94EA2B8E-2C00-4D29-8D5A-C7C6664DE9CE
2. Load the parameter in tag family and use it.
3. Create project parameter from shared parameter. (Project parameter with the same name that hasn't created from shared parameter don't work)
4. Fill the values in columns and tag them
Kostas Kouris
