I am dimensioning to studs.
Tabbing through to find the stud face in plan seems inconsistent. There are several instances where it's not possible to tab to the face.
Is there a rule or a common issue that makes it so the stud face, or any material face, in plan, cannot be selected?
have you try to install latest updates from autodesk sometimes it fixes issues. thanks
betcha you are trying to TAB-Select Wall Wrapped Ends. No can do. I gave you the workaround on your other thread. Use Ref. Planes -- or Model the Wrapping (my recommendation) .
