Hey, guys!
I'm having a problem which seems to be machine-specific.
I have Revit and AutoCAD installed on two machines - laptop and my tower.
When i open Revit 2015 or AutoCAD 2015 on my tower, the whole machine freezes, i get weird laggs and the internet connection disappears. The tower PC is completely compatible running these to softwares and I have absolutely no problems on my Laptop (the other machine) although the specs are much worse. The silly thing is that i've made a clean OS install of Windows 10 on both machines this week. One for my laptop just to clean up the system, and my tower PC, just to try and make this issue go away.
There seems to be no problem while i'm working with the programs, just when the splashscreen comes on...
cinizz,
This is the Revit API forum. You should post this question on the main Revit forum for better support.
https://forums.autodesk.com/t5/revit/ct-p/2003
-Pat
Hi @cinizz
Welcome to the Autodesk community!![]()
Sorry to hear that you are facing issues. the first thing to check is to see if you have the latest updates for your Revit version from your Autodesk Desktop app.
Next, try the recommendations on this thread and see if it helps resolve your issue.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
