Hi Teacher,
I accidentally "Purge Unused" all the "Walls" category in my exercise file.
Could you please tell me how can I restore and get the Walls' "System Families" back, with all its default "Types",
I tried "Load Family" and go to the "Library Folder" in C drive, but there isn't a "Walls" folder,
I already installed the 1.9Gb Library Content Package from the Autodesk website.
I also tried the bottom right beside "Load Autodesk Family", but there isn't a "Walls" category either,
I am also wondering if there is a complete list of all the "System Famililes" under each "Built-in Categories" (that I can alway see pressing VG)
Thank you in advance!!
Use Transfer Project Standards to bring into your Project what you need from another Project.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-2A49FE80-1B07-4C95-A0FE-42CE2001F3C2
Thank you so much!
It works!!!
Could you still explain why I cannot find the Walls "System Families" in the "library Folder", and
If there is a standard list of all "System Families" by default.
Thank you so much for the education!
System families aren't families you can load in. They work in a set way, and can only be customized so much, namely by adding and defining layers.
You could also load a file as group to load the desired families into your file
Did you like this post? Don't forget to like and accecpt as solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
You made me curious about loading a file as group. I'm still not sure how it will help me in daily life... it looks like you import the whole project and it will be a group. and that brings in the system families.
But I found this video that covers loading files as group a little bit
https://www.youtube.com/watch?v=RB83NgE7JNY&ab_channel=BalkanArchitect
