System Browser Missing
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1736 Aufrufe, 5 Antworten
I am a new user and traying to preform and energy analysis on a model. However, I cannot add anything to my system zones as I do not have access to the system browser:
F9 does not work either.
What am I doing wrong? How do I get the system browser to display?
Nathan
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: Anonymous
Are you using LT?
Rob
Nachricht 3 von 6
constantin.stroescu
  1. If you have Revit full options then go to Options >User Interface > check all three System Tabs for MEP
  2. If you have Revit LT then you have no MEP available
Constantin Stroescu
Nachricht 4 von 6
constantin.stroescu
how it can be solved if you have Revit full Options:
Constantin Stroescu
Nachricht 5 von 6
als Antwort auf: constantin.stroescu
Yes using full version @RobDraw
Thank you @constantin.stroescu  for you answer and detailed help. Really appreciate it.  That has fixed it.
Nathan
Nachricht 6 von 6
ted.linsley
If Rob Draw's solution doesn't work and you are using multiple monitors, unplug the 2nd and subsequent monitors.  I had this problem after undocking the System Browser.  It didn't re-appear until I unplugged one of my two monitors.
