I modeled with structural steel hollow columns instead of architectural columns and sections/elevations shown single lines only. How to edit structural columns so that width of columns are shown on sections/elevations.
Gelöst! Gehe zur Lösung
Yes, that's it. All structural framing elements show as single-line at coarse detail level.
i used architectural column, at all detail levels the column appears to be as a single line, even if it is plan or elevation or section
@maneeshcharugundla hello, what do you mean? post some screen shot to see. try to set your detail level to FINE and visual style to SHADED and see if helps. thanks
