synchronizing tube connections with sandwich plates from Advance Steel to Revit
1 ANTWORT 1
Nachricht 1 von 2
238 Aufrufe, 1 Antwort
Hi
Mi name is Felipe and I am working in a project where I need synchronize a steel connection from advance steel to Revit (both 2019 version). The steel connection is of type tube connections with sandwich plates additional objects. I use a base plate for connect the the column and bracing (rectangular profile). The problem is the following. When I synchronize the steel connection from AS to Revit, in the latter only appears the gusset and plates but not the bolts. I have not achieved the reason of this problem. Somebody could help me please?
Thank you!
1 ANTWORT 1
Nachricht 2 von 2
Luiscko
als Antwort auf: Anonymous
Maybe you need to update your version , 2019.1 or reinstall your plug in.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
