This is causing issues. Why is this greyed out and uncheckable? How to fix?
Gelöst! Gehe zur Lösung
Gelöst von andrew8QEC8. Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
This is because you are not an owner of any User-created workset. So you can't relinquish what you do not own.
What is the exact issue you are dealing with?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
The exact problem is that when I synch up the changes I make to the model, no one else is able to edit the file anymore without my permission for every little thing, in spite of synchronizing with the green spinning circle with Christmas present icon rather than the Christmas present with the lightning bolt. I think that it will work what you suggested.
