Sync to Autodesk Cloud hangs if sheet with shadow view is open
1 ANTWORT 1
Nachricht 1 von 2
luisPDAN6
158 Aufrufe, 1 Antwort
Hi!
We have noticed on Revit 2022 that if a sheet containing views with shadows is open, the synchronization to Autodesk Cloud hangs and says "uploading". If the view is closed, the synchronization works correctly. Would be great someone from Autodesk looks into that.
1 ANTWORT 1
Nachricht 2 von 2
cbt990
als Antwort auf: luisPDAN6
I find that I am more likely to encounter sync issues when performing a sync while a sheet is opened that has many graphics-intensive views, including with shadows. Try switching over to a regular floor plan as a best practice if you keep running into this.
Revit is amazing
