Sync/Save issue in Revit
4 ANTWORTEN 4
Nachricht 1 von 5
dhakshanamurthy.sriraman
300 Aufrufe, 4 Antworten
 Does Anyone know why the error is coming While saving/Syncing the model
And i tried this solution from Autodesk,.Its not working
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-fails-to-sny...
4 ANTWORTEN 4
Nachricht 2 von 5
  • does anyone else have the model open?
  • Are you working in the cloud?
  • Are you able to save locally?
Nachricht 3 von 5
handjonathan
als Antwort auf: Ryan_GormanKT36T
Hi @dhakshanamurthy.sriraman
Thanks a lot for posting your question to the forums!   It would be great if you could confirm some more specific details of your issue as described by @Ryan_GormanKT36T .
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 5
Hi, (late, reaction maybe solved by now :))
No background processes active in panel?
On a rare occasion I get this for Color Fill calculations, but it would mention that in the dialog, below the link btw maybe some info in it helps.
Cannot-save-this-document-because-Color-Fills-are-calculating-error-in-Revit.html
Any third-party addins, Audit model/create new local, issue also with other users?
- Michel
Nachricht 5 von 5
I am not sure does opened that model on that time, and yes, it's a shared cloud model. Same error is coming when we try to save locally.
