I have a Revit family that I have been struggling with trying to keep symbolic lines from hiding. I currently have a ceiling-based generic family of a curtain on a track and i have the curtain tied to an on/off visibility parameter and the track to another on/off parameter. However, when I turn off the curtain in a project, the symbolic lines disappear with it, as if Revit has for some reason grouped them together. I've checked lines inside the family editor to make sure they weren't tied to any parameters, redrawn the lines, changed the line subcategory and rebuilt the entire family to see if anything would work. Nothing has worked so far and I cant seem to figure out why Revit is hiding the symbolic lines along with the curtain in my plan view. Has anyone else had a similar issue?
Gelöst! Gehe zur Lösung
Gelöst von semko_dm. Gehe zur Lösung
Here's the project with the family loaded in and placed on the ceiling. It's a Revit 2017 File.
There are two families. Which one do you need to look at?
And just to be clear, which elements do you want to see in Floor Plan and which to see in RCP?
Before digging into fixing it, are you aware that if you use visibility check box to turn off the track or the curtain, they physically do not exist, meaning disappear in all views such as in sections, elevations, 3D views, etc...?
I don't think Visibility checkbox is appropriate for what you are after.
Hi!
You need something, that can be cut by plan, when you turn off geometry. In one family you have a vertical model line (invisible subcategory), but if you switch it to visible subcategory, and then look at it in the project, you'll find that the line goes in wrong direction. So, you have to correct the direction and length of that line and everything will be ok.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
I like that answer, A good trick to keep the family "cut" even if there is no visible geometry so that it still shows annotation lines is to use a reference line.
It worked on Revit 2015, and should still work on the newest versions. (haven't had to use the trick on R2017 yet)
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Just checked and the trick still works on revit 2017!
Thank you!
I had been struggling trying to figure out why it would hide everything when I turn off the curtain. I've had it just hide everything and I'd draw a new model line and it would hide the curtain and keep the symbolic lines but also show the track in plan view whenever I'd turn the curtain off. This seems to solve my issue though!
