When inserted into a 1/8" scale plan view, the symbolic line representation for these lockers does not show up as a hidden line. However, it does show up correctly when the view scale goes up to 1/4" or larger. How do we fix it?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Went down to 1/32" dashes and spaces. No go.
Yes. All under New Construction. I just changed the scale on the view that I was using to test the family.
FOr some reason, 1/16" worked for me! So setting the linetype in the family was not enough? Needed to be present in the project as well?
