I have a sheet with a wall group Named SW16-M.
I went to rename it to SW16, i ungroup ,regroup & rename it to SW16 no problem.
When i go to a FP view of the walls with the previous SW16-M select it and switch the group to the identical wall but new name SW16, Revit has a fatal error!
This is not the first time this has happened doing something similar.
Not a pc issue
Using:
Revit 2024
CPU:I9 13900K 24 cores
64GB DDR5 6000
This is not an idea. You need to submit this as a ticket item by contacting support and submitting through "Using and troubleshooting my software".
