Switch Join Order error
We found what we believe is another issue in Revit.
We created a concrete beam (to allow for a window below it) inside a wall. Of course, Revit warns that the beam is not visible because it is entirely placed inside this wall. We want to make this beam visible to allow for it being seen as a construction element on plans.
We solve this by using the Modify > Geometry > Join command: Switch Join Order.
It doesn't work. Furthermore, Revit warns that a serious error has occurred, and that a recovery file will be created. This does not end the application, work can be continued.
We made a screencast demonstrating this error:
The only solution to the problem we found was setting the Structural Usage of the wall to "Shear". Only then can the join order of wall & beam be manipulated to the required setting, in order to make it visible.
We encounter this frequently in different projects.
Can this be recognized as an issue to which a solution may be offered in one of the next updates?
Regards
Bram Vana
