Hi there,
Anybody knows how to control the line weight of sweeps inside a wall type?
Here is a picture that shows my problem. The sweep does not take the line weight of the wall core.
Any ideas guys?
Thank you for your reply. This doesn't solve the problem since we use the overide host layers as the graphic standard in my country demands that the thick lines will not be at the wall finish rather at the wall core. When the overide layers is on all other wall definitions are nulled. At least that is what I understand from trying.
I see what you did. This is a workaround. That is not what I meant. I wanted to know if there is a built-in control method. I guess there isn't.
So pitty they don't bother to upgrade so many aspects of the software....
Many thanks anyway!
