Sweeps in Floor Plan
IS there a way to hide the sweeps from the walls in the floor plan?
If built as part of the wall, no there isn't.  You can turn them off it they are created as a regular sweep, but you need to select it and change the category of the modeled element to Wall Sweep then it is a matter of turning off that subcategory under Walls.
