Hi, I made a custom profile & loaded it into project, but when i try to model in place/sweep a warning comes up saying "can't create sweep, error" i can't figure out the problem i have done many sweeps already. i attached an image of the sweep & the error message i got.
Thanks a lot!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Is that a Profile. If so, the Profile is probably F'ed up. Likely it has overlapping lines in it. Remove 'em, reload and try again.
...also, if you have line segments in the Profile that are less that 1/32", that will throw this error too.
Fix the profile sketch and make sure it is one closed loop, no overlapping.
