Sweep using an parametric polygone
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
marianne.berube-dufourM72N3
312 Aufrufe, 1 Antwort
Bonjour! I'm working on a family ( generic adaptative template ) and I first created a parametric polygone (diameter and number of sides are parameters) . I would like to make a sweep with this polygon along a path but when I select the polygon and the path line  Revit doesn't allow me to create a form. Thank you for your help!
polypathpolypath
1 ANTWORT 1
Nachricht 2 von 2
Yea the repeater won't allow you to create form until you remove the repeater.
