My wall sweep profile is cutting my wall but is leaving a small portion (at the profile chamfer) of the finish layer that it is cutting into. Any tips on how to get the finish layer to be completely cut by this profile, without changing the profile? Thanks.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can add a little reveal to trim that sucker off.
or, modify the layer, unlock the padlock so that you can grip stretch the top of the layer down to lower than the sweep.
Thanks ToanDN. Using the reveal worked.
I did try to unlock the layer and drag it down but it dragged the whole wall down not just the finish layer. I even selected each layer and unlocked all of them but it still dragged down the whole wall.
Thanks again! I was dragging the layer in the 'Edit Assembly' preview window, and didn't realize that I should drag it in model space. Very helpful!
