I've used sweep many times before, this has never been an issue but oddly after drawing my path on the initial birds eye Revit view it keeps informing me that plane is too sharp when I then try to draw the shape in an elevation view.
Stranger still, it allows me to draw at the impossibly sharp top down plan, which of course then does not work if I finish the sweep.
Looks like it's "Current" workplane is skewed to the view.
I typically draw sweeps in 3D views using pick lines method.
cheers for the reply, I'm starting to think it is a Revit error, does not let me draw on the desired plane in 3D either, having issues again with another project. Might be time to reinstall it.
