Hi, I am working with sweep walls to create an angle wall at one side. The problem is when I add windows does not cut all the way through or when I try to make an opening. If someone can have any idea please let me know, it would be great, thank you
-Try using an in-place Void family to cut the wall opening.
- You could also try using a Void inside the Window family to cut the wall.
- You could try to edit the profile of the wall to cut a hole in it.
It depends on how you created the window family. I have just tried an OOTB window and it works fine.
