Working on a project with a lot of moulding. I am needing a sweep to follow along a ramp. I am having trouble figuring this one out.
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Hello
@ToanDN As Toan mentioned, use railing, ( custom profile ), so that it can follow the ramp.
I usually use ramp, copied further up and then edit the profile in case of curbs ( kerbs )..
In Place sweep can work , use the ramp edge as a guide.
have a look.
Ramp, copied further up and edit profile.
you can pick and edit the edge , when you are in pick path it will show the point to drag along..
In Place sweep using ramp edge... you can customise the profile..
I got it to work by selecting the edge of the ramp, thank you for your help @Corsten.Au !
