SW wall profile wont follow with wrapped ends
2 ANTWORTEN 2
Nachricht 1 von 3
264 Aufrufe, 2 Antworten
Hi, im adding a profile to my sw wall in the top, i also have the corner sw elements wrapped but here the profile wont wrap around the corner when viewed in 3d mode in revit or when exported to for example IFC. Also, the layers is not visible in 3d viewing, its looks just like a solid block. What am i doing wrong ?
See example Pictures.
Wrapping works / looks fine in plan view:
In section view wall top profile looks fine:
However in 3d view (revit) but also when exported to ifc, neither wrapping (and the top profile that should follow the wrap) or layers, for example the insulation is showing:
Alexander
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Wall wrapping is just cosmetic -- shown with line work in Plan View only.  No modeled part of the wall is actually wrapped.
Also be aware that wrapping has no BIM value. It cannot be quantified.
Nachricht 3 von 3
Instead of wrapping ends, Allow Automatic Join.  Maybe cycle through wall join options by using the Wall Joins tool on the Modify tab.
