I've ran a Model check using the model checker and get a fail on the survey point as below:
I then ran the RevitLookup tool and got the AsDouble value noted In the model checker as below:
My survey point values are as below:
I know that my survey point is in the correct place for my model but would like the Asdouble value exposed to match my survey point data so this error clears in the model checker.
Does anyone know how I can achieve this?
And how can 3 values (Northing, Easting, and Elevation) match one number?
The double from the Revit lookup tool represents the N/S value of the survey point only. The lookup tool shows the northing, wasting and elevation as separate parameters.
There's no indication in the checker on how you make the values match and the lookup tool has no way that I can see of making them match either
Puzzling....
In the Model Checker SETUP dialog, there is a field to enter the expected value. I don't see a screenshot in your original post so I am not sure if you are updating that before you run your check.
