Surface pattern not showing on a wall
arma0404
arma0404
Hi everyone,
I'm setting up my graphics this way, where vertical lines should be 117mm away from each other:
Yet, in a section, the model shows vertical lines 70 mm apart:
What am I doing wrong? 70 mm was the old pattern, I updated it to reflect the current choices for the facade.
Thank you.
Remove paint from the wall.
arma0404
How was I supposed to know 😭
It worked! Thank you.
