Hello everyone,
I created a parametric family for barrel vault insertion from the metric generic model adaptive, which seems to work perfectly. (pic_01).
Unfortunately, when I open the family in the project file, it is impossible to display the vault surface, and therefore impossible to select it to create a roof surface (pic_02).
Where is the error?
Thank you very much
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Looks like the adaptive object is void and not solid. It will not show when you load into project. Try changing the void to solid.
hi syman2000!
thank you very much, indeed, with this operation I solved the problem. I had followed a tutorial on the subject and was sure that the void was loaded in the project, but I was surely wrong. Anyway solved! Thank you!
