Surface edge pattern for concrete foundation slab or floor
4 ANTWORTEN 4
Nachricht 1 von 5
1368 Aufrufe, 4 Antworten
Good day,
Surface pattern is not applied to the EDGE of floor or foundation slab? But the cut pattern is correct. Others families (concrete): Isolated, Wall, Slabe edge and Piles cup are correct (surface pattern). See pic. attached. Thx.
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
hmunsell
als Antwort auf: Anonymous
the material only gets applied to the top surface, not the exposed edges. you can use the Paint tool to apply a material to the edge or select Create Parts (but that has other effects you may not want).
https://autode.sk/2QtHEZq
Howard Munsell
Nachricht 3 von 5
als Antwort auf: hmunsell
Hello Howard,
Thank you a lot for some tips.
But. See attached.
Nachricht 4 von 5
hmunsell
i showed 2 options. which option did you try?
if i remember correctly, the Paint option will only work on the surface it is applied to. if you have a sections in a different place, the Painted surface will not be applied.
If you select the Create Parts, it should apply to anywhere that surface is shown. make sure you set your parts visibility, in the view properties, to Show Parts
Howard Munsell
Nachricht 5 von 5
Hi, Now it worked! Thank you a LOT.
