Support request - MEP behind sections are visible
1 ANTWORT 1
Nachricht 1 von 2
Marcus.Isacsson
234 Aufrufe, 1 Antwort
Hi fellas!
Anyone with a real quickfix or solution to this problem?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/MEP-elements-locat...
Status:Investigation of the incident is complete and a resolution has not been determined at this time.
Workaround:As an alternative solutions:
  • Move the section slightly forward to avoid the projection of MEP elements.
  • Rotate project to True North.
  • Hide element in view."
What does Autodesk mean with "Rotate project to True North".
We have a bunch of MEP that are shown in a wrong way but that we would like to show. What would you do?
The links are dw
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
jvpantin2
als Antwort auf: Marcus.Isacsson
This is "rotate project to true north",
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-CD5FEE13-B63E-4668-AC03-7D0E8A4C9698
but have no clue of how it will solve the issue...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
