Support family in Handrail Type only show "none"
3 ANTWORTEN 3
Nachricht 1 von 4
2348 Aufrufe, 3 Antworten
Hi
Im using Revit 2018 student version and using a pre-customized template. In the Project Browser - Families - Railings -  Handrail Type - Property - Supports - Family dropdown, i can only choose "None".(attachment file)
But if i use the default architecture template, in that menu i can choose "Support - Metal - Circular". So i think there must be something wrong with the customized template, and i want to ask someone for a way to fix this - the option to choose "Support - Metal - Circular" in the supports family dropdown in the customized template.
Many Thanks
Rgd.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Can't you Load the missing family from your Library into the Template (RTE) and/or the Project (RVT) itself?
Nachricht 3 von 4
Corsten.Au
Hi
There are no handrail families as such which you can import.
You can create a handrail profile family, import it and Create a handrail
using that profile..
If you copy paste stairs with handrail from one project to another, that will
bring in the handrails with their associated profile along..
cheers!
Corsten
Building Designer
Nachricht 4 von 4
als Antwort auf: Corsten.Au
Maybe I am misreading the OP, but FWIW, here's a link (from Autodesk Knowledge Network) to an RVT file that has Railing Supports in it:
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2016/...
