I'm sure there is a simple way to do this but I can't seem to figure it out. Is there a way to have the sun setting be different in different views for the sake of the drawings composition?
Thanks in advance. Any help is greatly appreciated.
Mike.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You can set the sun settings up in a View Template, then assign the View Template to the view(s).
Repeat as necessary.
Sun settings are specific to the view. So, simply change sun settings for each view.
Sure. Sun Settings can vary by view. Define via Graphic Display Options under Visual Styles.
That's right! I was approaching this from an entirely different perspective (view templates) and lost my way. Thank you so much for the reeducation.
Mike
FWIW---The original question was "how to set sun settings on multiple views". You can control sun settings/include them in View Templates, then apply to many views.
(i.e.The original question was not "how to set sun settings"?)
