When I click on the sun path in the plan view, it just displays 2 perpendicular lines and the time, but the sun path with the yellow sun path line is not visible. But it works fine in the 3D view. What is going on?
Solved by ToanDN. Go to Solution.
When I click on the sun path in the plan view, it just displays 2 perpendicular lines and the time, but the sun path with the yellow sun path line is not visible in neither plan nor 3D.
please help
