Sun Location Problem
3 ANTWORTEN 3
Nachricht 1 von 4
A328048
249 Aufrufe, 3 Antworten
When i tried to put a location to my project, the program crash, do i need to update to latest version? this didn't happened with latest versions. what guarantees me that it won't happen again? (for example, when 2024 version came out, i stilled use 2022 for a few months and nothing happened) It's kinda upset because that means i need to update a few devices.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: A328048
Can you translate those messages in your screenshots to English?
Also, it is highly unlikely your issue is related to product version.  My guess is that it's related to Internet Connection. Maybe Permissions.  Maybe Firewall.  Etc. Etc.
Nachricht 3 von 4
A328048
als Antwort auf: barthbradley
Screenshot (4). There has been an unrecoverable error, the program will close now. all your data has been recently saved, so it is not necessary to create recovery files, select help or press F1 to get more information about the possible causes of unrecoverable errors.
Screenshot (3). Do you only want to see the content of the website that was delivered securely? This website contains content that will not be provided using a secure HTTPS connection that can compromise the security of the entire page. (I've never seen this caption before, i tried to set the location on two different devices, even two differents places [at my work, then my house] and nothing changed)
Nachricht 4 von 4
A328048
Also, i use TwinMotion for renders, i'm kinda worried that if i update to 2025, i'm not going to be able to import my model
